Disables redistribution of routes between OSPF instances.
| vr | Specifies Virtual Router. |
| vr-name | Specifies the source Virtual Router for exported routes. |
| route-type | Specifies the OSPF inter-VR export route type. |
The default setting is disabled.
Use this command to stop OSPF from exporting routes between other protocols.
The following command disables OSPF to redistribute routes between OSPF instances:
disable ospf export vr ??
This command was first available in ExtremeXOS 32.3.
